Saltar al contenido principal
LG Voyager Antenna Replacement
Qué necesitas
  1. LG Voyager Antenna Replacement, Battery: paso 1, imagen 1 de 1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Antenna Replacement: paso 2, imagen 1 de 1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Antenna Replacement: paso 3, imagen 1 de 1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Antenna Replacement, Antenna: paso 4, imagen 1 de 1
    • First remove the battery by pulling the tab away from the device
    • Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
  5. LG Voyager Antenna Replacement: paso 5, imagen 1 de 2 LG Voyager Antenna Replacement: paso 5, imagen 2 de 2
    • Next remove the 6 #00 Phillips screws holding the back in place
    • screws: 1.43mm head, 3.61mm length
  6. LG Voyager Antenna Replacement: paso 6, imagen 1 de 3 LG Voyager Antenna Replacement: paso 6, imagen 2 de 3 LG Voyager Antenna Replacement: paso 6, imagen 3 de 3
    • Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
    • Gently work the plastic opening tool around the edge of the case to separate the two pieces
    • Once the case has been separated you should be able to see the circuitry inside the phone
  7. LG Voyager Antenna Replacement: paso 7, imagen 1 de 3 LG Voyager Antenna Replacement: paso 7, imagen 2 de 3 LG Voyager Antenna Replacement: paso 7, imagen 3 de 3
    • Remove the #00 Philips screw holding the antenna in place
    • Screw: 4.52mm length, 2.68mm head
    • Once the screw is removed, lift the small case around the antenna off
  8. LG Voyager Antenna Replacement: paso 8, imagen 1 de 2 LG Voyager Antenna Replacement: paso 8, imagen 2 de 2
    • Now that you have the antenna exposed, you can remove it
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 17-26, Amido Spring 2012 Miembro de Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 291
