Saltar al contenido principal
LG VX8700 LCD Screen Replacement
Qué necesitas
  1. LG VX8700 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 LG VX8700 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 LCD Screen Replacement: paso 2, imagen 1 de 2 LG VX8700 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 LCD Screen Replacement, Front Bezel: paso 3, imagen 1 de 1
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  4. LG VX8700 LCD Screen Replacement: paso 4, imagen 1 de 2 LG VX8700 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  5. LG VX8700 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  6. LG VX8700 LCD Screen Replacement: paso 6, imagen 1 de 2 LG VX8700 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
  7. LG VX8700 LCD Screen Replacement, Ear Piece: paso 7, imagen 1 de 1
    • Desolder the top ear piece using a soldering iron to remove the component
    • The ear piece is the black component that is located at the top with black and red wires
  8. LG VX8700 LCD Screen Replacement: paso 8, imagen 1 de 2 LG VX8700 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Remove the ear piece from the phone by lifting it using a plastic opening tool.
  9. LG VX8700 LCD Screen Replacement, LCD Screen: paso 9, imagen 1 de 1
    • Desolder the wires connected to the LCD board using a soldering iron
  10. LG VX8700 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Disconnect the Ribbon connecting the two pieces carefully with the plastic opening tool.
  11. LG VX8700 LCD Screen Replacement: paso 11, imagen 1 de 1
    • Remove the LCD screen.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 8-16, Maness Winter 2012 Miembro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,583
