Introducción
The guide outlines the steps necessary to replace the keypad on the LG VX8700. The keypad is used to to help direct actions on the phone.
Qué necesitas
Remove the back cover by sliding the tab away from the phone using one finger.
Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
Un comentario
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
