Saltar al contenido principal
Partes
No se especificaron partes.
  1. Turn the phone off. Remove the back cover by sliding the tab away from the phone using one finger.
    • Turn the phone off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. Lift one side of the battery using a plastic opening tool or your fingers.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
  3. When installing the battery, make sure to align the metal pins with those of the phone.
    • When installing the battery, make sure to align the metal pins with those of the phone.
  4. Turn your phone around and open the flip phone.
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  5. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  6. Remove the screen by using the tab to eject the screen. There is a gap between the case and the screen near the ear piece
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  7. Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  8. Turn your phone around Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
  9. Now we have the LCD outer case off. The LCD display can be seen on the left, the camera on the right.
    • Now we have the LCD outer case off. The LCD display can be seen on the left, the camera on the right.
    • Place the phone assembly down, it is not needed anymore.
  10. To remove the camera the ribbon connector should be removed.
    • To remove the camera the ribbon connector should be removed.
    • This ribbon connector is glued to the case, using the plastic opening tool pry the connector off.
  11. The camera should come loose after the connector is pried off.
    • The camera should come loose after the connector is pried off.
    • Take the new camera and apply a small square of double sided tape to the new ribbon connector.
Conclusión
Andrew
Miembro Desde 20/01/12
7 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-16, Maness Winter 2012 Miembro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 583
