Saltar al contenido principal
LG VX8560 Side Key Replacement
Qué necesitas
  1. LG VX8560 Side Key Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: paso 2, imagen 1 de 1
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: paso 3, imagen 1 de 2 LG VX8560 Side Key Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: paso 4, imagen 1 de 2 LG VX8560 Side Key Replacement, Side Keys: paso 4, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: paso 5, imagen 1 de 3 LG VX8560 Side Key Replacement: paso 5, imagen 2 de 3 LG VX8560 Side Key Replacement: paso 5, imagen 3 de 3
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: paso 6, imagen 1 de 2 LG VX8560 Side Key Replacement: paso 6, imagen 2 de 2
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Conclusión
Una persona más ha completado esta guía.
Kevin
Miembro Desde 04/18/13
7 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-62, Johann Spring 2013 Miembro de Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 242
