Saltar al contenido principal
LG VX8550 Camera Replacement
Qué necesitas
  1. LG VX8550 Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery release up.
  2. LG VX8550 Camera Replacement: paso 2, imagen 1 de 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Camera Replacement, Case: paso 3, imagen 1 de 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Camera Replacement: paso 4, imagen 1 de 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Camera Replacement: paso 5, imagen 1 de 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Camera Replacement: paso 6, imagen 1 de 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Camera Replacement: paso 7, imagen 1 de 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Camera Replacement, Motherboard: paso 8, imagen 1 de 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Camera Replacement: paso 9, imagen 1 de 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Camera Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Camera Replacement, Keypad Housing: paso 11, imagen 1 de 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Camera Replacement: paso 12, imagen 1 de 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Camera Replacement: paso 13, imagen 1 de 1
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Camera Replacement, Front Case: paso 14, imagen 1 de 1
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Camera Replacement: paso 15, imagen 1 de 1
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Camera Replacement: paso 16, imagen 1 de 1
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Camera Replacement: paso 17, imagen 1 de 1
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Camera Replacement: paso 18, imagen 1 de 1
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Camera Replacement: paso 19, imagen 1 de 1
    • Separate the two halves.
  20. LG VX8550 Camera Replacement, Camera: paso 20, imagen 1 de 1
    • With the screen casing separated from the slider mechanism the camera circuit board is visible.
    • Carefully lift up on the connector to unplug it from the circuit board.
  21. LG VX8550 Camera Replacement: paso 21, imagen 1 de 1
    • Lift up slowly on the connector cable to peel the camera off the adhesive backing.
  22. LG VX8550 Camera Replacement: paso 22, imagen 1 de 1
    • Remove camera from the casing.
Conclusión
Nathan Jones
Miembro Desde 04/10/10
89 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 34-55, Forte Spring 2010 Miembro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,394
