Saltar al contenido principal
Introducción
Sat on your phone and cracked the outer screen? Replace it.
NOTE: Replacing the outer screen requires replacing the entire outer casing.
Partes
No se especificaron partes.
  1. Using Tweezers, remove 4 rubber screw covers.
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
    • Align new face plate where cracked face plate perviously was.
Conclusión
Nichole Shaw
Miembro Desde 13/04/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-75, Johann Spring 2010 Miembro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,573
