Saltar al contenido principal
Introducción
Phone won't charge, and the charger is functional? Replace your phone's charging adapter.
NOTE: Charging adapter is attached to the logic board, so replacement requires replacing the logic board.
Partes
No se especificaron partes.
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. Remove four screws beneath battery using screw driver.
    • Remove four screws beneath battery using screw driver.
    • Remove three rubber screw covers with tweezers.
    • Remove the three screws under the covers with the screwdriver.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Detach outer casing from back of phone.
    • Detach outer casing from back of phone.
    • NOTE: There will be a significant amount of resistance to detaching the back casing.
  6. Unsnap gold rectangular plate and silver square plate from the logic board.
    • Unsnap gold rectangular plate and silver square plate from the logic board.
  7. Remove logic board, being careful not to remove any other pieces.
    • Remove logic board, being careful not to remove any other pieces.
    • Insert new logic board with white side facing down.
    • NOTE: Make sure side buttons on logic board are correctly aligned to avoid future complications.
  8. Replace logic board to replace charging adapter.
    • Replace logic board to replace charging adapter.
Conclusión
Nichole Shaw
Miembro Desde 13/04/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-75, Johann Spring 2010 Miembro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,369
