Saltar al contenido principal
LG VX6100 Keypad Replacement
Qué necesitas
  1. LG VX6100 Keypad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: paso 2, imagen 1 de 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: paso 3, imagen 1 de 1
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: paso 5, imagen 1 de 2 LG VX6100 Keypad Replacement: paso 5, imagen 2 de 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: paso 6, imagen 1 de 1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: paso 7, imagen 1 de 1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Conclusión
Teal
Miembro Desde 04/17/12
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-39, Regan Spring 2012 Miembro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 538
