Introducción
These steps show how to remove the phone's front case. This allows access to many of the components located on the outer face of the phone.
  1. Remove the four grey plugs using either tweezers or a push pin.
    • Remove the four grey plugs using either tweezers or a push pin.
  2. Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  5. The case can now be removed and the interior of the front is accessible.
    • The case can now be removed and the interior of the front is accessible.
Conclusión
Ryan Bishop
Miembro Desde 17/04/12
1 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-39, Regan Spring 2012 Miembro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Miembros
16 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 684
