Saltar al contenido principal
LG VX6100 Battery Replacement
Qué necesitas
  1. LG VX6100 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
  2. LG VX6100 Battery Replacement: paso 3, imagen 1 de 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
Conclusión
If after completing the replacement, the device still does not operate properly, further troubleshooting must be done to find and solve the issue.
Eric Funsten
Miembro Desde 04/17/12
1 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-39, Regan Spring 2012 Miembro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 821
