Introducción
You will mainly be dealing with the top portion of the phone in this guide. You will only be working with and installing the plastic screen protector in front of the LCD screens.
Partes
No se requieren partes.
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Una persona más ha completado esta guía.
