Introducción
In order to install a new camera to your LG VX5600, you will be required to disassemble most of the top half of the phone.
Qué necesitas
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located at the upper left and right corners.
Una persona más ha completado esta guía.
