Saltar al contenido principal
LG VX5500 Phone Casing Replacement
Qué necesitas
  1. LG VX5500 Phone Casing Replacement, Battery: paso 1, imagen 1 de 3 LG VX5500 Phone Casing Replacement, Battery: paso 1, imagen 2 de 3 LG VX5500 Phone Casing Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Phone Casing Replacement, Mother Board: paso 2, imagen 1 de 2 LG VX5500 Phone Casing Replacement, Mother Board: paso 2, imagen 2 de 2
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Phone Casing Replacement: paso 3, imagen 1 de 3 LG VX5500 Phone Casing Replacement: paso 3, imagen 2 de 3 LG VX5500 Phone Casing Replacement: paso 3, imagen 3 de 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Phone Casing Replacement: paso 4, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 4, imagen 2 de 2
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Phone Casing Replacement: paso 5, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 5, imagen 2 de 2
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
  6. LG VX5500 Phone Casing Replacement, Phone Casing: paso 6, imagen 1 de 2 LG VX5500 Phone Casing Replacement, Phone Casing: paso 6, imagen 2 de 2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  7. LG VX5500 Phone Casing Replacement: paso 7, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 7, imagen 2 de 2
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  8. LG VX5500 Phone Casing Replacement: paso 8, imagen 1 de 3 LG VX5500 Phone Casing Replacement: paso 8, imagen 2 de 3 LG VX5500 Phone Casing Replacement: paso 8, imagen 3 de 3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  9. LG VX5500 Phone Casing Replacement: paso 9, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 9, imagen 2 de 2
    • Use the tweezers to lift the display adapter off the screen component.
  10. LG VX5500 Phone Casing Replacement: paso 10, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 10, imagen 2 de 2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  11. LG VX5500 Phone Casing Replacement: paso 11, imagen 1 de 2 LG VX5500 Phone Casing Replacement: paso 11, imagen 2 de 2
    • Remove the earpiece and gyroscope by lifting them out of the phone casing using tweezers.
    • The earpiece and gyroscope are adhered to the phone casing so it will take a small amount of force to remove them.
    • Be careful when removing these components as the connecting wires are easily broken/disconnected.
  12. LG VX5500 Phone Casing Replacement: paso 12, imagen 1 de 1
    • Lift the screen components out of the phone.
  13. LG VX5500 Phone Casing Replacement: paso 13, imagen 1 de 1
    • The phone is now fully disassembled.
    • Replace the parts indicated with your new phone casing.
Conclusión
3 personas más completaron esta guía.
Henry
Miembro Desde 04/12/12
181 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-33, Maness Spring 2012 Miembro de Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 571
