Introducción
The following guide will show the complete tear down of the phone in order to replace the internal phone casing.
Qué necesitas
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
3 personas más completaron esta guía.
