Introducción
Batteries can become damaged or corrupted by constant usage. If your battery refuses to hold a charge or will not charge, follow this guide to take out and replace the battery.
  1. Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery. Our device did not come with a battery cover so it is not shown here. Remove the battery using your finger to pry it out of the battery housing.
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-33, Maness Spring 2012 Miembro de Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 576
