Saltar al contenido principal
LG VX5400 Phone Casing Replacement
Qué necesitas
  1. LG VX5400 Phone Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Phone Casing Replacement: paso 2, imagen 1 de 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Phone Casing Replacement: paso 3, imagen 1 de 3 LG VX5400 Phone Casing Replacement: paso 3, imagen 2 de 3 LG VX5400 Phone Casing Replacement: paso 3, imagen 3 de 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Phone Casing Replacement, Outer Casing: paso 4, imagen 1 de 1
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Phone Casing Replacement: paso 5, imagen 1 de 1
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Phone Casing Replacement, Phone Casing: paso 6, imagen 1 de 3 LG VX5400 Phone Casing Replacement, Phone Casing: paso 6, imagen 2 de 3 LG VX5400 Phone Casing Replacement, Phone Casing: paso 6, imagen 3 de 3
    • Pry open the phone and remove the keypad and logic board.
  7. LG VX5400 Phone Casing Replacement: paso 7, imagen 1 de 2 LG VX5400 Phone Casing Replacement: paso 7, imagen 2 de 2
    • Lay out and organize the parts of the phone. You can now put the inner parts of the phone into the new case.
Conclusión
Tyler
Miembro Desde 04/15/10
20 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 26-26, Regan Spring 2010 Miembro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,332
