Saltar al contenido principal
LG VX5400 Logic Board Replacement
Qué necesitas
  1. LG VX5400 Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Logic Board Replacement: paso 2, imagen 1 de 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Logic Board Replacement: paso 3, imagen 1 de 3 LG VX5400 Logic Board Replacement: paso 3, imagen 2 de 3 LG VX5400 Logic Board Replacement: paso 3, imagen 3 de 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Logic Board Replacement, Outer Casing: paso 4, imagen 1 de 1
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Logic Board Replacement: paso 5, imagen 1 de 1
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Logic Board Replacement, Logic Board: paso 6, imagen 1 de 2 LG VX5400 Logic Board Replacement, Logic Board: paso 6, imagen 2 de 2
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  7. LG VX5400 Logic Board Replacement: paso 7, imagen 1 de 2 LG VX5400 Logic Board Replacement: paso 7, imagen 2 de 2
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
Conclusión
2 personas más completaron esta guía.
Sourabh
Miembro Desde 04/15/10
132 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 26-26, Regan Spring 2010 Miembro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,512
