Saltar al contenido principal
LG VX5300 outer LCD screen replacement
Qué necesitas
  1. LG VX5300 outer LCD screen replacement, Front LCD Screen: paso 1, imagen 1 de 1
    • Remove the rubber stoppers from the four corners of the front screen.
  2. LG VX5300 outer LCD screen replacement: paso 2, imagen 1 de 1
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. LG VX5300 outer LCD screen replacement: paso 3, imagen 1 de 2 LG VX5300 outer LCD screen replacement: paso 3, imagen 2 de 2
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. LG VX5300 outer LCD screen replacement, LCD Screen: paso 4, imagen 1 de 2 LG VX5300 outer LCD screen replacement, LCD Screen: paso 4, imagen 2 de 2
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. LG VX5300 outer LCD screen replacement: paso 5, imagen 1 de 1
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. LG VX5300 outer LCD screen replacement: paso 6, imagen 1 de 1
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. LG VX5300 outer LCD screen replacement: paso 7, imagen 1 de 1
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
Conclusión
Ashley
Miembro Desde 02/12/13
13 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-1, Buehl Spring 2013 Miembro de Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Miembros
4 Guías creadas
Un comentario
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 489
