Saltar al contenido principal
LG VX5200 Screen Replacement
Qué necesitas
  1. LG VX5200 Screen Replacement, Screen: paso 1, imagen 1 de 3 LG VX5200 Screen Replacement, Screen: paso 1, imagen 2 de 3 LG VX5200 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: paso 2, imagen 1 de 2 LG VX5200 Screen Replacement: paso 2, imagen 2 de 2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: paso 3, imagen 1 de 2 LG VX5200 Screen Replacement: paso 3, imagen 2 de 2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: paso 4, imagen 1 de 3 LG VX5200 Screen Replacement: paso 4, imagen 2 de 3 LG VX5200 Screen Replacement: paso 4, imagen 3 de 3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: paso 5, imagen 1 de 3 LG VX5200 Screen Replacement: paso 5, imagen 2 de 3 LG VX5200 Screen Replacement: paso 5, imagen 3 de 3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
Conclusión
jmarcum
Miembro Desde 10/28/09
16 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-18, Regan Fall 2009 Miembro de Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Miembros
2 Guías creadas
Un comentario
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 3,406
