Saltar al contenido principal
LG VX5200 Rear Body Panel Disassembly
Qué necesitas
  1. LG VX5200 Rear Body Panel Disassembly, Battery: paso 1, imagen 1 de 2 LG VX5200 Rear Body Panel Disassembly, Battery: paso 1, imagen 2 de 2
    • Turn the phone on its back.
  2. LG VX5200 Rear Body Panel Disassembly: paso 2, imagen 1 de 2 LG VX5200 Rear Body Panel Disassembly: paso 2, imagen 2 de 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Rear Body Panel Disassembly: paso 3, imagen 1 de 2 LG VX5200 Rear Body Panel Disassembly: paso 3, imagen 2 de 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Rear Body Panel Disassembly, LG VX5200 Rear Body Panel Disassembly: paso 4, imagen 1 de 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Rear Body Panel Disassembly: paso 5, imagen 1 de 3 LG VX5200 Rear Body Panel Disassembly: paso 5, imagen 2 de 3 LG VX5200 Rear Body Panel Disassembly: paso 5, imagen 3 de 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Rear Body Panel Disassembly: paso 6, imagen 1 de 3 LG VX5200 Rear Body Panel Disassembly: paso 6, imagen 2 de 3 LG VX5200 Rear Body Panel Disassembly: paso 6, imagen 3 de 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Rear Body Panel Disassembly: paso 7, imagen 1 de 1
    • Check to see that your device looks like the attached photo.
Conclusión
Equipo
Cal Poly, Team 4-13, Forte Winter 2010 Miembro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,263
