Introducción
A guide to removing the LCD screen.
Turn the phone on its back.
  • Turn the phone on its back.
Agregar Comentario
Orient the phone as shown.
  • Orient the phone as shown.
  • Remove the battery cover by pushing upward with your thumb.
Agregar Comentario
  • Place your fingernail at the top of the battery and pry the battery out towards you.
Agregar Comentario
  • Flip the phone open.
  • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
  • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
Agregar Comentario
  • Insert the plastic opening tool in the seam of the top portion of the flip phone.
  • Gently pry the seam open.
  • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
Agregar Comentario
  • Close the flip phone.
  • Hold the base of the phone and gently remove the faceplate.
  • Place the phone and the faceplate on a clean, flat surface.
Agregar Comentario
  • Try not to move the thin component wires as they will bend and break very easily.
  • The speaker is the dark gray, larger circular-shaped piece to the right of the battery. Attached to it are the four thin wires.
  • The vibrator wires are thinner and even more fragile.
Agregar Comentario
  • Remove the white stopper from the camera light located above the gold connector.
  • Lift the gold connector up with your finger to detach it.
Agregar Comentario
  • Gently lift out the speaker with your fingertip.
Agregar Comentario
  • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
  • Gently remove the vibrator with tweezers.
  • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
Agregar Comentario
  • Place phone body and LCD screen on a clean, lint-free surface.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Douglas Blaalid
Miembro Desde 13/01/10
282 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 4-13, Forte Winter 2010 Miembro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 3,494
