Saltar al contenido principal
LG VX5200 Camera Replacement
Qué necesitas
  1. LG VX5200 Camera Replacement, Battery: paso 1, imagen 1 de 2 LG VX5200 Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone on its back.
  2. LG VX5200 Camera Replacement: paso 2, imagen 1 de 2 LG VX5200 Camera Replacement: paso 2, imagen 2 de 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Camera Replacement: paso 3, imagen 1 de 2 LG VX5200 Camera Replacement: paso 3, imagen 2 de 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Camera Replacement, Face Plate: paso 4, imagen 1 de 3 LG VX5200 Camera Replacement, Face Plate: paso 4, imagen 2 de 3 LG VX5200 Camera Replacement, Face Plate: paso 4, imagen 3 de 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Camera Replacement: paso 5, imagen 1 de 3 LG VX5200 Camera Replacement: paso 5, imagen 2 de 3 LG VX5200 Camera Replacement: paso 5, imagen 3 de 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Camera Replacement: paso 6, imagen 1 de 3 LG VX5200 Camera Replacement: paso 6, imagen 2 de 3 LG VX5200 Camera Replacement: paso 6, imagen 3 de 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 Camera Replacement, Camera: paso 7, imagen 1 de 3 LG VX5200 Camera Replacement, Camera: paso 7, imagen 2 de 3 LG VX5200 Camera Replacement, Camera: paso 7, imagen 3 de 3
    • Locate the phone camera.
    • Locate the white rubber stopper to left of the camera.
    • Remove white rubber stopper by grabbing an edge with your fingers and gently pulling it off.
  8. LG VX5200 Camera Replacement: paso 8, imagen 1 de 2 LG VX5200 Camera Replacement: paso 8, imagen 2 de 2
    • Lift the copper ribbon cable up from the bottom right hand corner.
  9. LG VX5200 Camera Replacement: paso 9, imagen 1 de 2 LG VX5200 Camera Replacement: paso 9, imagen 2 de 2
    • While holding the copper connection out of the way, use your fingernail to pry the camera out of its socket.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 4-13, Forte Winter 2010 Miembro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,226
