Introducción
Repairing the logic board.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. Remove the rubber grommet using a Spudger.
    • Remove the rubber grommet using a Spudger.
  4. Be sure not to lose the screws. They are small!
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  6. When removing back cover, be careful not to break the speaker wires. Using an iPod Opening Tool, carefully pry off the back cover. Using Tweezers, gently pull speaker wires out.
    • When removing back cover, be careful not to break the speaker wires.
    • Using an iPod Opening Tool, carefully pry off the back cover.
    • Using Tweezers, gently pull speaker wires out.
  7. Separate the two halves.
    • Separate the two halves.
  8. Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool.
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  9. Carefully flip the logic board up and out of the way.
    • Carefully flip the logic board up and out of the way.
  10. Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out.
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  11. DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • De-solder solder joint on front using Soldering Iron.
  12. De-solder solder joint on the back using Soldering Iron.
    • De-solder solder joint on the back using Soldering Iron.
  13. Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board.
    • Carefully detach ribbon cable and remove logic board.
Conclusión
David Foster
Miembro Desde 11/04/10
1 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 25-88, Amido Spring 2010 Miembro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Miembros
18 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,467
