Saltar al contenido principal
Introducción
Replacing the LCD screen.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. Remove 4 rubber grommets using the Spudger.
    • Remove 4 rubber grommets using the Spudger.
  4. Remove 4 screws using the Phillips #00 Screwdriver.
    • Remove 4 screws using the Phillips #00 Screwdriver.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool.
    • Carefully pry off outer cover using iPod Opening Tool.
  7. Remove speaker using the Spudger. Remove speaker using the Spudger.
    • Remove speaker using the Spudger.
  8. Remove vibrator using the Spudger. Remove vibrator using the Spudger.
    • Remove vibrator using the Spudger.
  9. Lift up LCD display using iPod Opening Tool. Lift up LCD display using iPod Opening Tool.
    • Lift up LCD display using iPod Opening Tool.
  10. DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  11. Pry off ribbon cable using iPod Opening Tool. Pry off ribbon cable using iPod Opening Tool.
    • Pry off ribbon cable using iPod Opening Tool.
Conclusión
David Foster
Miembro Desde 11/04/10
1 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 25-88, Amido Spring 2010 Miembro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,205
