Saltar al contenido principal
LG VX4500 Rear Cover Replacement
Qué necesitas
  1. LG VX4500 Rear Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Rear Cover Replacement: paso 2, imagen 1 de 2 LG VX4500 Rear Cover Replacement: paso 2, imagen 2 de 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Rear Cover Replacement, Rear Cover: paso 3, imagen 1 de 1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Rear Cover Replacement: paso 4, imagen 1 de 1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Rear Cover Replacement: paso 5, imagen 1 de 3 LG VX4500 Rear Cover Replacement: paso 5, imagen 2 de 3 LG VX4500 Rear Cover Replacement: paso 5, imagen 3 de 3
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Rear Cover Replacement: paso 6, imagen 1 de 1
    • Separate the two halves.
Conclusión
Matthew Hagan
Miembro Desde 04/12/10
5 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 25-88, Amido Spring 2010 Miembro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 1,456
