Saltar al contenido principal
LG VX4500 Motherboard Replacement
Qué necesitas
  1. LG VX4500 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Motherboard Replacement: paso 2, imagen 1 de 2 LG VX4500 Motherboard Replacement: paso 2, imagen 2 de 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Motherboard Replacement, Rear Cover: paso 3, imagen 1 de 1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Motherboard Replacement: paso 4, imagen 1 de 1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Motherboard Replacement: paso 5, imagen 1 de 3 LG VX4500 Motherboard Replacement: paso 5, imagen 2 de 3 LG VX4500 Motherboard Replacement: paso 5, imagen 3 de 3
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Motherboard Replacement: paso 6, imagen 1 de 1
    • Separate the two halves.
  7. LG VX4500 Motherboard Replacement, Keypad: paso 7, imagen 1 de 3 LG VX4500 Motherboard Replacement, Keypad: paso 7, imagen 2 de 3 LG VX4500 Motherboard Replacement, Keypad: paso 7, imagen 3 de 3
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 Motherboard Replacement: paso 8, imagen 1 de 1
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 Motherboard Replacement: paso 9, imagen 1 de 3 LG VX4500 Motherboard Replacement: paso 9, imagen 2 de 3 LG VX4500 Motherboard Replacement: paso 9, imagen 3 de 3
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 Motherboard Replacement: paso 11, imagen 1 de 1
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 Motherboard Replacement: paso 12, imagen 1 de 3 LG VX4500 Motherboard Replacement: paso 12, imagen 2 de 3 LG VX4500 Motherboard Replacement: paso 12, imagen 3 de 3
    • Carefully detach the ribbon cable and remove the motherboard.
Conclusión
David Foster
Miembro Desde 04/11/10
1 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 25-88, Amido Spring 2010 Miembro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 12
Todo El Tiempo: 1,570
