Introducción
This guide will show you how to replace the screen.
Partes
No se requieren partes.
  1. Remove the four rubber stoppers around the main screen using a pointed-end spudger Remove the four rubber stoppers around the main screen using a pointed-end spudger
    • Remove the four rubber stoppers around the main screen using a pointed-end spudger
  2. Use a number #00 Philips screwdriver to unscrew the four screws under the rubber stoppers
    • Use a number #00 Philips screwdriver to unscrew the four screws under the rubber stoppers
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use a plastic opening tool, pry the top end open Whilst prying the top panel with one plastic opening tool, use a thinner iPod opening tool to slide down the gap and pry open the case Free the opposite side in the same manner
    • Use a plastic opening tool, pry the top end open
    • Whilst prying the top panel with one plastic opening tool, use a thinner iPod opening tool to slide down the gap and pry open the case
    • Free the opposite side in the same manner
  5. Remove plastic screen panel to reveal internal components Remove plastic screen panel to reveal internal components
    • Remove plastic screen panel to reveal internal components
  6. Remove the screen board by lifting away from the phone Remove speaker by prying with a spudger Remove speaker by prying with a spudger
    • Remove the screen board by lifting away from the phone
    • Remove speaker by prying with a spudger
  7. Once screen board is pulled away, gently press out the plastic screen Once screen board is pulled away, gently press out the plastic screen Once screen board is pulled away, gently press out the plastic screen
    • Once screen board is pulled away, gently press out the plastic screen
Conclusión
Nico Chiarito
Miembro Desde 21/01/10
22 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-47, Regan Winter 2010 Miembro de Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,329
