1. Push the light gray rectangle in the top-center up. While pushing up grab the sides of the battery and pull out. While pushing up grab the sides of the battery and pull out.
    • Push the light gray rectangle in the top-center up.
    • While pushing up grab the sides of the battery and pull out.
  2. Unscrew the antenna by grasping the base and twisting counterclockwise.
    • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
  3. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
    • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone. The bit size is engraved on the base of the bit head.
    • Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone.
    • The bit size is engraved on the base of the bit head.
  6. With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone. Gently pull the two pieces apart to separate. Apply enough force to separate the pieces without cracking the back cover.
    • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
    • Gently pull the two pieces apart to separate.
    • Apply enough force to separate the pieces without cracking the back cover.
  7. Lift the computer chip to gain access to the keypad and side buttons beneath. CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
    • Lift the computer chip to gain access to the keypad and side buttons beneath.
    • CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
  8. Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace. Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace. Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace.
    • Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace.
Conclusión
Nico Chiarito
Miembro Desde 21/01/10
22 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-47, Regan Winter 2010 Miembro de Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,605
