Saltar al contenido principal
LG VX4400 Antenna Replacement
  1. LG VX4400 Antenna Replacement, Battery: paso 1, imagen 1 de 3 LG VX4400 Antenna Replacement, Battery: paso 1, imagen 2 de 3 LG VX4400 Antenna Replacement, Battery: paso 1, imagen 3 de 3
    • Press the light grey button in the top-center on the back of the phone.
    • While pressing, slide the battery and cover up.
  2. LG VX4400 Antenna Replacement, Antenna: paso 2, imagen 1 de 1
    • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
Linea de Meta
Nico Chiarito
Miembro Desde 01/21/10
22 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-47, Regan Winter 2010 Miembro de Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,380
