Introducción
In this video, I will show you how to replace LG V30 standard or wide-angle back camera.
This guide will show you how to replace both the standard and wide-angle rear cameras in the LG V30 smartphone. If your rear cameras are producing blurry or glitchy photos, or if your cameras are failing to function at all, replacing them should alleviate your issues.
Qué necesitas
Resumen del Video
Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
Pull the SIM card tray out from the phone.
Herramienta utilizada en este paso:Plastic Cards$2.99
Use a suction cup to lift up the back cover up.
Insert the edge of a plastic card into the space created between the cover and frame.
2 personas más completaron esta guía.
