Saltar al contenido principal
LG V30 Plus Front-Facing Camera Replacement
Qué necesitas
  1. LG V30 Plus Front-Facing Camera Replacement, Rear Glass: paso 1, imagen 1 de 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Front-Facing Camera Replacement: paso 2, imagen 1 de 2 LG V30 Plus Front-Facing Camera Replacement: paso 2, imagen 2 de 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Front-Facing Camera Replacement: paso 3, imagen 1 de 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Front-Facing Camera Replacement, Motherboard: paso 4, imagen 1 de 2 LG V30 Plus Front-Facing Camera Replacement, Motherboard: paso 4, imagen 2 de 2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Front-Facing Camera Replacement: paso 5, imagen 1 de 3 LG V30 Plus Front-Facing Camera Replacement: paso 5, imagen 2 de 3 LG V30 Plus Front-Facing Camera Replacement: paso 5, imagen 3 de 3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Front-Facing Camera Replacement: paso 6, imagen 1 de 2 LG V30 Plus Front-Facing Camera Replacement: paso 6, imagen 2 de 2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Front-Facing Camera Replacement: paso 7, imagen 1 de 2 LG V30 Plus Front-Facing Camera Replacement: paso 7, imagen 2 de 2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Front-Facing Camera Replacement: paso 8, imagen 1 de 1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Front-Facing Camera Replacement, Battery: paso 9, imagen 1 de 3 LG V30 Plus Front-Facing Camera Replacement, Battery: paso 9, imagen 2 de 3 LG V30 Plus Front-Facing Camera Replacement, Battery: paso 9, imagen 3 de 3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
  10. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: paso 10, imagen 1 de 2 LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: paso 10, imagen 2 de 2
    • Use a Spudger to pry away the front-facing camera from the board.
Conclusión
Samuel Jahnke
Miembro Desde 04/22/19
279 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S1-G3, Maness Spring 2019 Miembro de Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 260
