Saltar al contenido principal
LG V30 Battery Replacement
Qué necesitas
Resumen del Video
LG V30 Battery Repair Guide
  1. LG V30 Battery Replacement, Power Off: paso 1, imagen 1 de 3 LG V30 Battery Replacement, Power Off: paso 1, imagen 2 de 3 LG V30 Battery Replacement, Power Off: paso 1, imagen 3 de 3
    • Drain the battery's charge below 25%.
    • Power off the phone by pressing and holding the Power/Lock key on the backside of the phone for three seconds. Tap the Power Off option and Power Off to confirm.
  2. LG V30 Battery Replacement, Remove SIM Tray/Card: paso 2, imagen 1 de 3 LG V30 Battery Replacement, Remove SIM Tray/Card: paso 2, imagen 2 de 3 LG V30 Battery Replacement, Remove SIM Tray/Card: paso 2, imagen 3 de 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  3. LG V30 Battery Replacement, Heat Backing's Adhesive: paso 3, imagen 1 de 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. See the iOpener instructions guide to learn how to use an iOpener.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. LG V30 Battery Replacement: paso 4, imagen 1 de 3 LG V30 Battery Replacement: paso 4, imagen 2 de 3 LG V30 Battery Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  5. LG V30 Battery Replacement: paso 5, imagen 1 de 3 LG V30 Battery Replacement: paso 5, imagen 2 de 3 LG V30 Battery Replacement: paso 5, imagen 3 de 3
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  6. LG V30 Battery Replacement: paso 6, imagen 1 de 3 LG V30 Battery Replacement: paso 6, imagen 2 de 3 LG V30 Battery Replacement: paso 6, imagen 3 de 3
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  7. LG V30 Battery Replacement, Remove Back Cover: paso 7, imagen 1 de 3 LG V30 Battery Replacement, Remove Back Cover: paso 7, imagen 2 de 3 LG V30 Battery Replacement, Remove Back Cover: paso 7, imagen 3 de 3
    • Carefully remove the back cover, making sure that the adhesive is sliced through on all sides.
    • Because this phone's backing is attached using adhesive, you will need to replace the adhesive when re-assembling the phone.
  8. LG V30 Battery Replacement: paso 8, imagen 1 de 1
    • Remove the ten Phillips #000 screws from the midframe.
  9. LG V30 Battery Replacement: paso 9, imagen 1 de 3 LG V30 Battery Replacement: paso 9, imagen 2 de 3 LG V30 Battery Replacement: paso 9, imagen 3 de 3
    • Using a plastic spudger, pry up the midframe of the phone.
  10. LG V30 Battery Replacement, Remove Midframe: paso 10, imagen 1 de 2 LG V30 Battery Replacement, Remove Midframe: paso 10, imagen 2 de 2
    • Carefully pull the midframe from the rest of the phone's body.
    • The midframe is connected to the main body with a small slot on the right side of the midframe. Carefully free the frame from this slot by gently wiggling and pulling outwards at the same time.
  11. LG V30 Battery Replacement: paso 11, imagen 1 de 3 LG V30 Battery Replacement: paso 11, imagen 2 de 3 LG V30 Battery Replacement: paso 11, imagen 3 de 3
    • Use the plastic spudger to pry up the four press-fit connectors on the top portion of the motherboard.
  12. LG V30 Battery Replacement, Remove Speaker Assembly: paso 12, imagen 1 de 3 LG V30 Battery Replacement, Remove Speaker Assembly: paso 12, imagen 2 de 3 LG V30 Battery Replacement, Remove Speaker Assembly: paso 12, imagen 3 de 3
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  13. LG V30 Battery Replacement: paso 13, imagen 1 de 1
    • Use a heat gun to apply heat to the front face of the phone. This will soften the adhesive used to secure the phone's battery.
    • When using a heat gun or hair dryer to soften the adhesive, be careful not to overheat the battery. The hair dryer/heat gun will make the phone hot to the touch, so handle the phone with care.
    • Alternatively, you can place a heated iOpener across the top of the battery for approximately three minutes to soften the adhesive holding the battery to the device.
    • If you have multiple iOpeners, it is recommended to also put one on the screen side of the battery.
  14. LG V30 Battery Replacement: paso 14, imagen 1 de 3 LG V30 Battery Replacement: paso 14, imagen 2 de 3 LG V30 Battery Replacement: paso 14, imagen 3 de 3
    • Insert a plastic card at the bottom edge of the battery
    • Gently work the plastic card around the left side of the battery, separating the battery from its adhesive.
  15. LG V30 Battery Replacement, Remove Battery: paso 15, imagen 1 de 3 LG V30 Battery Replacement, Remove Battery: paso 15, imagen 2 de 3 LG V30 Battery Replacement, Remove Battery: paso 15, imagen 3 de 3
    • Use the plastic card to pry the battery upwards from its slot.
    • Use your fingers to lift the battery away from the phone.
    • Because this battery is attached using adhesive, you will need to replace the adhesive when installing a new battery.
Conclusión
To reassemble your device, follow these instructions in reverse order. After installing a new battery, run down its charge completely. Then, charge the battery fully. This will calibrate the new battery. Then, use the phone normally.
11 personas más completaron esta guía.
Witrigs
Miembro Desde 11/24/15
69,454 Reputación
378 Guías creadas
12 comentarios
Do you have to put the adhesive for the battery?
RT RT - Contestar
Suction cups on both sides, heatgun on the back pannel, then lift. Much easier. And you don't have to worry about breaking the back panel.
DJ Somebody - Contestar
Why can’t the idiots at LG, or indeed any other company, make a phone with an MQA capable DAC, and a replaceable battery?
tonywinter - Contestar
it is not about idiocy. When you do not conform to a set battery shape you can configure the insides of a phone for more performance and features. That being said the LG V30 does have a standard battery shape. So in this case it is a desire to create built in obsolescence. After all it is believed in the western world cell phone sales are flat.
Malinourn Malinourn -
And..as long as the battery is in the phone it can be used to track you…
Loud Harley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 56
Ultimos 30 días: 219
Todo El Tiempo: 27,490
