Saltar al contenido principal
LG V30 Rear Camera Replacement
Qué necesitas
Resumen del Video
  1. LG V30 Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 3 LG V30 Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 3 LG V30 Rear Camera Replacement, Rear Camera: paso 1, imagen 3 de 3
    • Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
    • Pull the SIM card tray out from the phone.
  2. LG V30 Rear Camera Replacement: paso 2, imagen 1 de 2 LG V30 Rear Camera Replacement: paso 2, imagen 2 de 2
    • Use a heat gun to apply heat to the back cover.
  3. LG V30 Rear Camera Replacement: paso 3, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 3, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  4. LG V30 Rear Camera Replacement: paso 4, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 4, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 4, imagen 3 de 3
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  5. LG V30 Rear Camera Replacement: paso 5, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 5, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 5, imagen 3 de 3
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  6. LG V30 Rear Camera Replacement: paso 6, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 6, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 6, imagen 3 de 3
    • Remove the back cover.
  7. LG V30 Rear Camera Replacement: paso 7, imagen 1 de 1
    • Remove the ten Phillips #000 screws from the midframe.
  8. LG V30 Rear Camera Replacement: paso 8, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 8, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 8, imagen 3 de 3
    • Using a plastic spudger, pry up the midframe of the phone.
  9. LG V30 Rear Camera Replacement: paso 9, imagen 1 de 2 LG V30 Rear Camera Replacement: paso 9, imagen 2 de 2
    • Remove the midframe.
  10. LG V30 Rear Camera Replacement: paso 10, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 10, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 10, imagen 3 de 3
    • Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
  11. LG V30 Rear Camera Replacement: paso 11, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 11, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 11, imagen 3 de 3
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  12. LG V30 Rear Camera Replacement: paso 12, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 12, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 12, imagen 3 de 3
    • Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
  13. LG V30 Rear Camera Replacement: paso 13, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 13, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 13, imagen 3 de 3
    • Use a spudger to pry up the motherboard and lift it out of the phone's frame.
  14. LG V30 Rear Camera Replacement: paso 14, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 14, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 14, imagen 3 de 3
    • Flip over the motherboard.
    • Using a plastic spudger, pry up the press fit connector for the first camera.
  15. LG V30 Rear Camera Replacement: paso 15, imagen 1 de 2 LG V30 Rear Camera Replacement: paso 15, imagen 2 de 2
    • Remove the camera with a pair of ESD safe tweezers.
  16. LG V30 Rear Camera Replacement: paso 16, imagen 1 de 3 LG V30 Rear Camera Replacement: paso 16, imagen 2 de 3 LG V30 Rear Camera Replacement: paso 16, imagen 3 de 3
    • Pry up the second camera with a spudger.
    • The press fit connector has already been disconnected, but the camera module is still lightly adhered to the motherboard.
    • Remove the second camera with a pair of tweezers.
Conclusión
2 personas más completaron esta guía.
Witrigs
Miembro Desde 11/24/15
69,454 Reputación
378 Guías creadas
Un comentario
Does this make it no longer waterproof?
Rob Hoover - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 2,430
