Saltar al contenido principal
LG V20 Primary Rear-Facing Camera Replacement
Qué necesitas
  1. LG V20 Primary Rear-Facing Camera Replacement, Battery: paso 1, imagen 1 de 3 LG V20 Primary Rear-Facing Camera Replacement, Battery: paso 1, imagen 2 de 3 LG V20 Primary Rear-Facing Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 Primary Rear-Facing Camera Replacement, Midframe Assembly: paso 2, imagen 1 de 1
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 Primary Rear-Facing Camera Replacement: paso 3, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 3, imagen 2 de 2
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 Primary Rear-Facing Camera Replacement: paso 4, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 Primary Rear-Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 Primary Rear-Facing Camera Replacement: paso 6, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 6, imagen 2 de 2
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 Primary Rear-Facing Camera Replacement: paso 7, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 7, imagen 2 de 2
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 Primary Rear-Facing Camera Replacement: paso 8, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 8, imagen 2 de 2
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 Primary Rear-Facing Camera Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard cover.
  10. LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: paso 10, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  11. LG V20 Primary Rear-Facing Camera Replacement, Motherboard Assembly: paso 11, imagen 1 de 1
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
  12. LG V20 Primary Rear-Facing Camera Replacement: paso 12, imagen 1 de 1
    • Disconnect the display flex cable with the flat end of a spudger.
  13. LG V20 Primary Rear-Facing Camera Replacement: paso 13, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement: paso 13, imagen 2 de 2
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
  14. LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: paso 14, imagen 1 de 2 LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: paso 14, imagen 2 de 2
    • Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera.
    • Use a pair of tweezers to remove the rear camera.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team S22-G5, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G5
Miembros de 4
36 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 21
Todo El Tiempo: 6,584
