Saltar al contenido principal
LG V10 Battery Replacement
Qué necesitas
  1. LG V10 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Battery Replacement: paso 2, imagen 1 de 2 LG V10 Battery Replacement: paso 2, imagen 2 de 2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
Conclusión
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 personas más completaron esta guía.
Nikolai Lesh
Miembro Desde 03/13/14
344 Reputación
1 Guía escrita
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 326
1,670 Guías creadas
0 Guide Comments
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 3,156
