Introducción
This guide will demonstrate how to properly replace the ear piece speaker. The ear piece speaker is located at the top of the phone near the front facing camera.
  1. Use the plastic opening tool to pry off the back cover. Use the plastic opening tool to pry off the back cover.
    • Use the plastic opening tool to pry off the back cover.
  2. Lift the battery out of place.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000). Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  5. Use a plastic opening tool to loosen the tabs around the edge of the phone. Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  6. Use a plastic opening tool or your finger to carefully disconnect the speaker. Use a plastic opening tool or your finger to carefully disconnect the speaker.
    • Use a plastic opening tool or your finger to carefully disconnect the speaker.
Conclusión
4 personas más completaron esta guía.
Equipo
UWS, Team 1-1, Schneider-Bateman Spring 2016 Miembro de UWS, Team 1-1, Schneider-Bateman Spring 2016
UWS-SCHNEIDER-BATEMAN-S16S1G1
3 Miembros
8 Guías creadas
That's cool how did you get this stuff planned it is awsome.
Taziah brown - Contestar
This is a brand new phone. Now I have to repair it? Something VERY WRONG with this picture! Is that the best sprint can do?
Ron Lieser - Contestar
Brand new out of the box phone and I have to repair the speaker. I don't think so!
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 13
Todo El Tiempo: 720
