Saltar al contenido principal
LG Tribute Rear-Facing Camera Replacement
Qué necesitas
  1. LG Tribute Rear-Facing Camera Replacement, Battery: paso 1, imagen 1 de 2 LG Tribute Rear-Facing Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Rear-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: paso 3, imagen 1 de 2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: paso 3, imagen 2 de 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Rear-Facing Camera Replacement: paso 4, imagen 1 de 2 LG Tribute Rear-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: paso 5, imagen 1 de 2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: paso 5, imagen 2 de 2
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 623
