Introducción
The motherboard is a circuit board that connects and controls the phone's components.
  1. Use the plastic opening tool to pry off the back cover. Use the plastic opening tool to pry off the back cover.
    • Use the plastic opening tool to pry off the back cover.
  2. Lift the battery out of place.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000). Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  5. Use a plastic opening tool to loosen the tabs around the edge of the phone. Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  6. Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  7. Remove SIM card by sliding it out of its housing. Remove the front-facing camera using a plastic opening tool. Remove rear-facing camera using a plastic opening tool.
    • Remove SIM card by sliding it out of its housing.
    • Remove the front-facing camera using a plastic opening tool.
    • Remove rear-facing camera using a plastic opening tool.
    • Connect these three components to the new motherboard.
Conclusión
3 personas más completaron esta guía.
Aaron Amdall
Miembro Desde 25/01/16
883 Reputación
4 Guías creadas
Equipo
UWS, Team 1-1, Schneider-Bateman Spring 2016 Miembro de UWS, Team 1-1, Schneider-Bateman Spring 2016
UWS-SCHNEIDER-BATEMAN-S16S1G1
3 Miembros
8 Guías creadas
ممكن تشريح بوردة lg ls660
nabeel - Contestar
For those that find this guide and are looking to dissasemble an lg tribute 2, Make sure to remove your sim card before romoving the cover that has screws. other than that its the same, but i spent a half hour removing my cover carefully just to find out the sd card had held the cover and motherboard togeather, causing Added risk of damage.
Christian Rolfe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 53
Todo El Tiempo: 3,063
