Saltar al contenido principal
LG Tribute 5 Headphone Jack Replacement
Qué necesitas
  1. LG Tribute 5 Headphone Jack  Replacement, Battery: paso 1, imagen 1 de 2 LG Tribute 5 Headphone Jack  Replacement, Battery: paso 1, imagen 2 de 2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Headphone Jack  Replacement: paso 2, imagen 1 de 3 LG Tribute 5 Headphone Jack  Replacement: paso 2, imagen 2 de 3 LG Tribute 5 Headphone Jack  Replacement: paso 2, imagen 3 de 3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 1 de 3 LG Tribute 5 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 2 de 3 LG Tribute 5 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 3 de 3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Headphone Jack  Replacement: paso 4, imagen 1 de 3 LG Tribute 5 Headphone Jack  Replacement: paso 4, imagen 2 de 3 LG Tribute 5 Headphone Jack  Replacement: paso 4, imagen 3 de 3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Headphone Jack  Replacement: paso 5, imagen 1 de 2 LG Tribute 5 Headphone Jack  Replacement: paso 5, imagen 2 de 2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Headphone Jack  Replacement: paso 6, imagen 1 de 1
    • Use an iFixit opening tool to remove the headphone jack.
Conclusión
Una persona más ha completado esta guía.
Kevin Hernon
Miembro Desde 04/22/19
298 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Miembro de UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 205
