Saltar al contenido principal
LG Treasure Rear Camera Replacement
Qué necesitas
  1. LG Treasure Rear Camera Replacement, Battery: paso 1, imagen 1 de 2 LG Treasure Rear Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Rear Camera Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Rear Camera Replacement, Rear Camera: paso 3, imagen 1 de 2 LG Treasure Rear Camera Replacement, Rear Camera: paso 3, imagen 2 de 2
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Rear Camera Replacement: paso 4, imagen 1 de 2 LG Treasure Rear Camera Replacement: paso 4, imagen 2 de 2
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
Conclusión
2 personas más completaron esta guía.
david amirahmadi
Miembro Desde 02/15/18
576 Reputación
5 Guías creadas
Equipo
UW Stout, Team S8-G5, Ogden Spring 2018 Miembro de UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 210
