Saltar al contenido principal
LG Thrill 4G Phone Buttons Replacement
Qué necesitas
  1. LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: paso 1, imagen 1 de 2 LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: paso 1, imagen 2 de 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Phone Buttons Replacement, Battery Removal: paso 2, imagen 1 de 2 LG Thrill 4G Phone Buttons Replacement, Battery Removal: paso 2, imagen 2 de 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Phone Buttons Replacement, Screw Removal: paso 3, imagen 1 de 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Phone Buttons Replacement, Speaker Removal: paso 4, imagen 1 de 2 LG Thrill 4G Phone Buttons Replacement, Speaker Removal: paso 4, imagen 2 de 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Phone Buttons Replacement, Buttons: paso 5, imagen 1 de 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Phone Buttons Replacement: paso 6, imagen 1 de 3 LG Thrill 4G Phone Buttons Replacement: paso 6, imagen 2 de 3 LG Thrill 4G Phone Buttons Replacement: paso 6, imagen 3 de 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Phone Buttons Replacement: paso 7, imagen 1 de 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
Conclusión
Kenny Richmond
Miembro Desde 01/20/15
260 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-6, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 546
