Saltar al contenido principal
LG Sunrise Midframe Replacement
Qué necesitas
  1. LG Sunrise Midframe Replacement, Back cover: paso 1, imagen 1 de 1
    • Flip the phone over so the back side is facing you.
  2. LG Sunrise Midframe Replacement: paso 2, imagen 1 de 1
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. LG Sunrise Midframe Replacement: paso 3, imagen 1 de 1
    • Set back panel aside for later use or to replace.
  4. LG Sunrise Midframe Replacement, Battery: paso 4, imagen 1 de 2 LG Sunrise Midframe Replacement, Battery: paso 4, imagen 2 de 2
    • Use your finger to pull out battery from the bottom of the device.
  5. Aviso: los pasos 5-6 provienen de una guía que está marcada como "En progreso".
    LG Sunrise Midframe Replacement, Lower Back Plastic Piece: paso 5, imagen 1 de 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: paso 5, imagen 2 de 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: paso 5, imagen 3 de 3
    • You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
  6. LG Sunrise Midframe Replacement: paso 6, imagen 1 de 1
    • Once both of the screws are out you can easily pop off the bottom piece.
  7. LG Sunrise Midframe Replacement, Midframe: paso 7, imagen 1 de 2 LG Sunrise Midframe Replacement, Midframe: paso 7, imagen 2 de 2
    • Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
  8. LG Sunrise Midframe Replacement: paso 8, imagen 1 de 2 LG Sunrise Midframe Replacement: paso 8, imagen 2 de 2
    • Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 235
