Saltar al contenido principal
Introducción
Is your phone not charging properly? Consider using and following the directions on this guide to replace the battery in your device.
Partes
No se especificaron partes.
  1. Flip the phone over so the back side is facing you.
    • Flip the phone over so the back side is facing you.
  2. Use a prying tool or a flat head screwdriver to pry the back cover from the device.
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  4. Set back panel aside for later use or to replace.
    • Set back panel aside for later use or to replace.
  5. Use your finger to pull out battery from the bottom of the device. Use your finger to pull out battery from the bottom of the device.
    • Use your finger to pull out battery from the bottom of the device.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 75
