Saltar al contenido principal
LG Stylo 2 Plus Mid-Frame Replacement
Qué necesitas
  1. LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: paso 1, imagen 1 de 3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: paso 1, imagen 2 de 3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: paso 1, imagen 3 de 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Mid-Frame Replacement, Battery: paso 2, imagen 1 de 3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: paso 2, imagen 2 de 3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: paso 2, imagen 3 de 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: paso 3, imagen 1 de 2 LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: paso 3, imagen 2 de 2
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
  4. LG Stylo 2 Plus Mid-Frame Replacement: paso 4, imagen 1 de 2 LG Stylo 2 Plus Mid-Frame Replacement: paso 4, imagen 2 de 2
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
Conclusión
Tiffany Wheeler
Miembro Desde 04/22/19
308 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Miembro de UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 155
