Saltar al contenido principal
LG Stylo 2 Plus Battery Replacement
Qué necesitas
  1. LG Stylo 2 Plus Battery Replacement, Rear Case: paso 1, imagen 1 de 3 LG Stylo 2 Plus Battery Replacement, Rear Case: paso 1, imagen 2 de 3 LG Stylo 2 Plus Battery Replacement, Rear Case: paso 1, imagen 3 de 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Battery Replacement, Battery: paso 2, imagen 1 de 3 LG Stylo 2 Plus Battery Replacement, Battery: paso 2, imagen 2 de 3 LG Stylo 2 Plus Battery Replacement, Battery: paso 2, imagen 3 de 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
Conclusión
Please dispose of the old battery properly by bringing it to a electronics recycling facility or calling the phone number on the back for more instructions.
Noah Kehm
Miembro Desde 04/22/19
241 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Miembro de UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 861
