Introducción
When replacing a battery make sure to rid the old battery responsibly.You will need the plastic separator tool or if you don't you can use your nails but it is highly not recommended as you could get injured.
Partes
No se requieren partes.
  1. First you need to remove the back case of the phone. Place the phone face down. Using the plastic opening tool, insert into the initial gap shown.
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Place the back case to the side. Use your finger or the opening tool to remove battery. Remove the battery carefully to not damage the phone or the battery.
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
Conclusión
3 personas más completaron esta guía.
Devon Barber
Miembro Desde 13/02/18
775 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S11-G1, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 15
Últimos 30 Días: 42
Todo El Tiempo: 413
