Introducción
If you are having issues with your motherboard, such as the blue screen of death, constant errors, or crashes you may need to replace the motherboard. This guide will take you through the necessary steps to replace the Motherboard.
Qué necesitas
Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
Use the plastic opening tool to lift up the connector that holds the camera to the board.
Casi Terminas!
Conclusión
