Saltar al contenido principal
LG Risio Rear-Facing Camera Replacement
Qué necesitas
  1. LG Risio Rear-Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 2 LG Risio Rear-Facing Camera Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Rear-Facing Camera Replacement, Battery: paso 2, imagen 1 de 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Rear-Facing Camera Replacement, Midframe: paso 3, imagen 1 de 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Rear-Facing Camera Replacement: paso 4, imagen 1 de 2 LG Risio Rear-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Rear-Facing Camera Replacement: paso 5, imagen 1 de 3 LG Risio Rear-Facing Camera Replacement: paso 5, imagen 2 de 3 LG Risio Rear-Facing Camera Replacement: paso 5, imagen 3 de 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Rear-Facing Camera Replacement: paso 6, imagen 1 de 1
    • Using your hand, pick up the midframe to separate it from the phone.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 115
