Saltar al contenido principal
LG Risio Motherboard Replacement
Qué necesitas
  1. LG Risio Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 LG Risio Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: paso 2, imagen 1 de 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: paso 3, imagen 1 de 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: paso 4, imagen 1 de 2 LG Risio Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: paso 5, imagen 1 de 3 LG Risio Motherboard Replacement: paso 5, imagen 2 de 3 LG Risio Motherboard Replacement: paso 5, imagen 3 de 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: paso 6, imagen 1 de 1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 LG Risio Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: paso 8, imagen 1 de 1
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 250
